Trouble setting up a 4in6 Tunnel
Jun 11th, 2009
I've been trying to set up this tunnel with no luck. I have a network like:
Node A <--> Switch 1 <--> Router1 <--> Vlan 1
Node B <--> Vlan 1
Node B <--> Qualnet
Node C <--> Qualnet
Node C <--> Vlan 2
Node D <--> Switch 2 <--> Router 2 <--> Vlan 2
Nodes B, C, and Qualnet are an ipv6 network.
Nodes A and D are ipv4.
When I try to ping D from A I sniff B and C with Wireshark. On both I can see the packet going from Router 1 towards Router 2. Then on C I see a response packet going from Router 2 to Router 1, but B doesn't show that packet, so it doesn't make it to B.
Router 1 and 2 are able to ping eachother. B and C can also ping both routers.
I've attatched my config files. Can anyone point out what I'm doing wrong?
*edit: In both my attachment files the key in "crypto isakmp key" should say "crypto isakmp key insecurekey45"
