WS-X45-SUP6-E QOS
Jun 11th, 2009
Dear Mister
I tried to configure QOS and certain features, like queueing, but the command line is very limited. Don't support the "qos" command. Show the next message:
Switch#show platform software qos interface tenGigabitEthernet 1/1 vlan 1 input
Qos policy is not programed into hardware on this target
Maybe the card need another module??? Best Regards
ssoberlik Wed, 06/17/2009 - 14:58
  • Bronze, 100 points or more
The QoS configuration with Sup6-E is different from other supervisors. The command "qos" does not exist, because Qos is always enabled. The trust feature is not supported as well, as the incoming traffic is trusted by default. So the command does not exist as well.
rodrigo.hernandez Tue, 06/23/2009 - 08:21
Well. My doubt mainly was related with the queue use in Supervisor VI.
Thank you very much for your helps. To all.
Best Regards
