Call Transfer Recall UC520
Jun 11th, 2009
  • Bronze, 100 points or more
I tried searching, btu I coudl not find anything that answers my question:
Is Call Transfer Recall a global feature option that all phones and users have?
or is it a feature to be added by phone or by user?
My understanding is that it is global.
You configure the timeouts transfer-recall seconds and then any extension without a CFB, with a CFNA timer greater than the transfer-recall timer will follow the call transfer rules... correct ?
and user's who always announce a transferred call won't even notice the feature is enabled... correct ?
Stacy
Marcos Hernandez Fri, 06/12/2009 - 13:20
  • Blue, 1500 points or more
Stacy,
It is not global, it has to be applied to the transferor (XOR) extension (not to the transfer-to target or XTO, nor to the transferee or XEE) .
The example below  shows that transfer-recall is enabled for ephone-dn 23 and after 60 seconds an unanswered call is forwarded back to the transferor. The timeouts transfer-recall command can also be set in an ephone-dn template which can then be applied to individual directory numbers.
ephone-dn 103
number 103
name Smith, John
timeouts transfer-recall 60
Marcos
Related Content
