Question related to OSPF process ID
Jun 11th, 2009
Hello Netpros,
My question is related to the OSPF different process ids running on a single router.Do there is any method to synchronize two different OSPF ids advertised network to the neighbor routing table.
R1#sh ip ospf database
OSPF Router with ID (10.10.2.1) (Process ID 12)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.10.2.1 10.10.2.1 192 0x80000001 0x00548B 1
OSPF Router with ID (2.2.2.2) (Process ID 28)
1.1.1.1 1.1.1.1 1042 0x80000008 0x00E943 4
2.2.2.2 2.2.2.2 1559 0x80000004 0x0038F1 4
3.3.3.3 3.3.3.3 1525 0x80000003 0x00F82B 4
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
9.0.0.0/32 is subnetted, 1 subnets
C 9.9.9.9 is directly connected, Loopback9
10.0.0.0/32 is subnetted, 6 subnets
O 10.10.2.2 [110/65] via 10.10.2.2, 00:48:18, Serial0/2
O 10.10.1.1 [110/65] via 10.10.0.1, 00:48:18, Serial0/0
O 10.10.0.1 [110/65] via 10.10.0.1, 00:48:18, Serial0/0
C 10.10.0.2 is directly connected, Loopback0
C 10.10.2.1 is directly connected, Loopback2
O 10.10.1.2 [110/65] via 10.10.2.2, 00:48:18, Serial0/2
R2#sh ip ospf database
OSPF Router with ID (10.10.2.2) (Process ID 12)
10.10.2.2 10.10.2.2 690 0x80000002 0x0020C0 1
OSPF Router with ID (3.3.3.3) (Process ID 28)
1.1.1.1 1.1.1.1 1103 0x80000008 0x00E943 4
2.2.2.2 2.2.2.2 1620 0x80000004 0x0038F1 4
3.3.3.3 3.3.3.3 1584 0x80000003 0x00F82B 4
R2#sh ip route
R2#sh ip route
8.0.0.0/32 is subnetted, 1 subnets
C 8.8.8.8 is directly connected, Loopback8
C 10.10.2.2 is directly connected, Loopback2
O 10.10.1.1 [110/65] via 10.10.1.1, 00:49:02, Serial0/1
O 10.10.0.1 [110/65] via 10.10.1.1, 00:49:02, Serial0/1
O 10.10.0.2 [110/65] via 10.10.2.1, 00:49:02, Serial0/2
O 10.10.2.1 [110/65] via 10.10.2.1, 00:49:02, Serial0/2
C 10.10.1.2 is directly connected, Loopback0
I know OSPF process id is used to identify the OSPF routing process and it kept different database table for each process.But just for a curiosity is this possible?
Prasad
Overall Rating: 5 (1 ratings)
Manish Prasad Thu, 06/11/2009 - 13:40
For more clarification
R1#sh run | be ospf
router ospf 28
router-id 2.2.2.2
log-adjacency-changes
network 10.10.0.2 0.0.0.0 area 0
network 10.10.2.1 0.0.0.0 area 0
router ospf 12
network 9.9.9.9 0.0.0.0 area 0
R2#sh run | be ospf
router ospf 28
router-id 3.3.3.3
network 10.10.1.2 0.0.0.0 area 0
network 10.10.2.2 0.0.0.0 area 0
router ospf 12
network 8.8.8.8 0.0.0.0 area 0
ip http server
no ip http secure-server
control-plane
Prasad
Edison Ortiz Thu, 06/11/2009 - 14:05
  • Hall of Fame,
    Founding Member
You can't synchronize them but you can redistribute between OSPF processes to have routes from each OSPF database distributed to their respective neighbors.
HTH,
__
Edison.
Manish Prasad Thu, 06/11/2009 - 14:12
Thank You Edison.
Could you give me any example how to redistribute between OSPF processes.
One more question when i was trying to add one more OSPF process on a single router i get some messages , please can you explain this....
"*Mar 1 00:32:24.755: OSPF: Start redist-scanning
*Mar 1 00:32:24.755: OSPF: Scan the RIB for both redistribution and translation
*Mar 1 00:32:24.775: OSPF: End scanning, Elapsed time 20ms^Z"
Prasad
Edison Ortiz Thu, 06/11/2009 - 14:16
  • Hall of Fame,
    Founding Member
router ospf 28
router-id 2.2.2.2
redistribute ospf 12 subnets
router ospf 12
redistribute ospf 28 subnets
How many OSPF processes are you adding? If more than 2, then you have a network design problem.
Actually, what's the reason for needing 2 OSPF processes now?
Manish Prasad Thu, 06/11/2009 - 15:12
OSPF hello packets do not contains process id.
So when the hello packet is exchanged with matching all the required field then atleast the neighbor router will make a INIT state relationship with this router(Process id doesn't matter here).
If so then why the neighborhood relationship table is not showing the adjacency with the router id 10.10.2.2..
R1#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
3.3.3.3 0 FULL/ - 00:00:36 10.10.2.2 Serial0/2
1.1.1.1 0 FULL/ - 00:00:38 10.10.0.1 Serial0/0
Prasad
Harold Ritter Thu, 06/11/2009 - 16:06
  • Cisco Employee,
Prasad,
Each interface can only belong to one ospf process. So the neighbor relationship will be established one of the two process ids for a given interface.
show ip ospf interface tells you which process id owns the interface.
