40% ping sucess rate?
Jun 11th, 2009
Problem:
I have a 40%-20% ping sucess rate from my inside interface to yahoo.com and a 100% sucess rate from my outside interface.
Setup:
I currnetly have a linksys RV082(192.168.0.1) connected to two ISP's. Connected to one of the switch ports on the RV082 is a Cisco 2821(WAN ip: 192.168.0.4). The Cisco 2821 is then connected to a regular switch, and compters are connected to that. The LAN ip on the Cisco 2821 is "192.168.4.1".
Suspected Problem:
Some of the default routes are not correct? (There may be other problems however) Any help is appreciated.
Default routes:
Cisco...0.0.0.0 0.0.0.0 192.168.0.1
Cisco...0.0.0.0 0.0.0.0 GigabitEthernet0/1 (WAN)
Cisco...0.0.0.0 0.0.0.0 GigabitEthernet0/0 (LAN)
Linksys...192.168.4.0 255.255.255.0 192.168.0.102
_______________________________________
cisco configuration file:
Building configuration...
Current configuration : 1636 bytes
version 12.4
hostname CiscoRouter
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$QKvL$DNWm2th4qX.xx2vb1hmG1/
enable password **********
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.4.1 192.168.4.9
ip dhcp excluded-address 192.168.4.200 192.168.4.254
ip dhcp pool LAN_POOL
import all
network 192.168.4.0 255.255.255.0
lease infinite
voice-card 0
no dspfarm
archive
log config
hidekeys
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$
ip address dhcp client-id GigabitEthernet0/1
ip nat outside
duplex auto
speed auto
router rip
network 192.168.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1 permanent
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.4.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password *************
login
scheduler allocate 20000 1000
end
Overall Rating: 5 (1 ratings)
Jerry Ye Thu, 06/11/2009 - 13:52
  • Cisco Employee,
Hi Michael,
You have three (3) static default routes
When you are pinging from the inside interface, the router will try to load balance the traffic to all these static default routes. You only need ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1.
HTH,
jerry
