Fabric Required?
Jun 11th, 2009
Anyone ever seen this or have ny input on this error.... Error is at the bottom on line starting with the number 2
Router#sh power
system power redundancy mode = redundant
system power redundancy operationally = non-redundant
system power total = 1370.04 Watts (32.62 Amps @ 42V)
system power used = 471.24 Watts (11.22 Amps @ 42V)
system power available = 898.80 Watts (21.40 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-1400-AC 1370.04 32.62 OK OK on
2 none
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 WS-C6503-E-FAN 57.54 1.37 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-SUP32-GE-3B 154.98 3.69 154.98 3.69 on on
2 WS-X6724-SFP 154.98 3.69 154.98 3.69 on off (Fabric required)
3 WS-X6148-GE-TX 103.74 2.47 103.74 2.47
Jon Marshall Thu, 06/11/2009 - 13:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mike
The WS-X6724-SFP is a fabric only module and it will only work with a Supervisor 720. The Supervisor 32 does not provide a connection to the fabric.
Unfortunately there is nothing you can do to get this to work other than to change the supervisor to a 720 or trade the module in for a non fabric only module ie.
any WS-X67... module will only work with the Supervisor 720.
Jon
mikegrous Thu, 06/11/2009 - 14:50
Jon i get what your saying however is this not conflicting to what ciscos site says? Or am i missing something.
• Operational consistency: Configurations available for Catalyst 6500 3-, 6-, 9-, and 13-slot chassis running Cisco IOS® Software and Cisco Catalyst Operating System Software; interoperable with all other interfaces and services modules; and forward-compatible with all Catalyst 6500 supervisor engines
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd801459a7.html
Jon Marshall Thu, 06/11/2009 - 15:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mike
Hmm, not entirely sure i get exactly what that means.
Scroll down in that doc past table 1 to the next table and you'll see that the WS-X6724-SFP and WS-X6748-SFP are only supported with the Supervisor 720.
Jon
Joseph W. Doherty Thu, 06/11/2009 - 16:16
I think it's a way of saying you can mix and match chassis and components, what's not stated, not all combinations are valid.
As Jon correctly notes, the 67xx series are CEF720 fabric only cards. Your 6724-SFP would work in any chassis slot with a sup720, but if it were a 6748-SFP or 6748-GE-TX, it would only work in slots 9..13 of a 6513.
Your sup32 will only support cards that will work with classic bus. Besides this exluding the 67xx cards, the WS-X6816-GBIC also is fabric only.
BTW, from your original post:
"1 WS-SUP32-GE-3B 154.98 3.69 154.98 3.69 on on
3 WS-X6148-GE-TX 103.74 2.47 103.74 2.47 "
mikegrous Fri, 06/12/2009 - 06:42
Ok i get it. Thanks alot. Looks like ill be going to the fabric store :)
Joseph W. Doherty Fri, 06/12/2009 - 08:28
Or you might consider using the WS-X6516A-GBIC or WS-X6416-GBIC.
Joseph W. Doherty Fri, 06/12/2009 - 09:12
Oh, guess I should add, if you find a WS-C6500-SFM or WS-C6500-SFM2 card at the "fabric store", it will not work with either a 6724-SFP or your sup32. Simple, eh? (laugh)
