Jun 11th, 2009
can i restrict client computer services in NAC solution by using nessus or agent ??
srue Fri, 06/12/2009 - 05:57
do you mean windows services, like in the control panel?
you can check to see if services are running or installed, i'm not sure you can 'control' them though - as in turning them off or on. that is probably best left to AD admins and their AD gpo's. blech!
sal_jam82 Fri, 06/12/2009 - 08:05
thanks for replying ,yes i mean if i want that my agent shudn't use telnet service so can i define it in client policy to put restrictions.
