snmp manager
Jun 11th, 2009
Hi. I've been trying to find an snmp server that would allow me to query snmp enable cisco devices for their cpu and ram utilization. These stats would then be saved by the snmp manager. However, after spending hours trying out many, i discovered that most require an mib for each corresponding cisco device. I have a 2960 switch.
I would really appreciate any help on this.
Collin Clark Fri, 06/12/2009 - 06:07
Take a look at Solarwinds Network Performance Monitor. It is a commercial product so you will have to pay, however they compile 1000's of MIBs so you don't have to do anything but add the IP and community string and it starts monitoring. You can then setup custom graphs based on compiled MIBs.
Hope that helps.
