Strange IPSEC message on 2821 ISR
Jun 11th, 2009
Hi everyone,
I have debug running on IPSec on my router, trying to isolate a tunnel drop problem, and the logs contain many lines with this message:
IPSEC(crypto_get_cm_handle_from_pak): Failed to create access pak subblock
Anyone know what this means? Thanks
auraza Fri, 06/12/2009 - 18:51
Best to get in touch with TAC for this. They should be able to look it up for you.
What version are you running?
northtexasnetworks Mon, 06/15/2009 - 12:52
Hi Auraza,
I will check with TAC, we are running Ver. 12.4(3f). Is this one know to have bugs?
auraza Mon, 06/15/2009 - 12:57
Mitchell, that is a pretty old version. I would go ahead and upgrade if that is a possibility and see if that fixes the problem for you, in which case it would most likely point to a bug.
zenon_electronics Mon, 09/07/2009 - 22:27
Hi, did you found what is the problem???
I have the same problem since 2 days. Before that everything worked fine!
I don't get any other debug logs from crypto... just this one:
IPSEC(crypto_get_cm_handle_from_pak):Failed to create access pak subblock
Pls help
northtexasnetworks Wed, 09/09/2009 - 09:29
To this day Cisco has not been able to say for sure what causes this message. It may be an IOS bug and it may be a hardware problem. In my situation we had other issues also, such as the VPN tunnel would drop and not come back until we did a reload on the router. I had to replace the router and also update the IOS to a newer release. The new router is running stable however we sometimes still get this error message
zenon_electronics Wed, 09/09/2009 - 23:12
Hi, thanks for your reply. I find where my problem is. I use ADSL connection with ADSL modem in front of my Cisco.
I just restarted my ADSL modem and everything went fine :)
Tihomir Yosifov
IT support
