Connect 2 offices with private point to point. What routers?
Jun 11th, 2009
Main office has internet access through a T1. They have a small office and a private point-to-point connection. They want to route the small office through the main office and out to the internet via the T1. Can someone give some advise on this? Looking for reasonable routers for both locations and some insite on setup.
paynster Fri, 06/12/2009 - 13:49
No. After looking around I am considering using a RVL200 and 2 RV042 routers. The RVL200 as the firewall/main router and a RV042 for each office.
paynster Mon, 06/15/2009 - 11:20
I think I'm all set. I am going to use 1 RVL200 connected to the provider, then 1 RV042 at each office with the outside interface configured on the LAN of the RVL200, then configure the RVL200 and the 2 RV042 with the subnets, static routes, etc. I think this will be a simple solution and these devices are reasonably priced. The documentation of the RVL200 has a good example solution and config that shows this implementation.
