Cisco WebVPN + AnyConnect on IOS with IPv6?
Jun 11th, 2009
I currently have a WebVPN + AnyConnect setup on a 871 router working #1. I am able to give out ip's from my own dhcp pool, a feature I greatly appreciate. Since my network is also v6-compliant and most of my stuff is transferred, how would I go to give out my prefix and RA through the VPN? My router is already setup for v6, the only thing I need to do is to tell it to AnyConnect.
Here is my setup:
ip dhcp excluded-address
ip dhcp pool lan
interface Vlan10
description $FW_INSIDE$
ip address
ip nat inside
ip virtual-reassembly
ipv6 address 2001:xxx:xxx:1::1/64
ipv6 enable
ip local pool sslclients
webvpn gateway gateway_1
ip address 69.xx.xx.xx port 443
ssl trustpoint TP-self-signed-506703934
webvpn install svc flash:/webvpn/svc_1.pkg sequence 1
webvpn context sslvpn
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group policy_1
functions svc-enabled
svc address-pool "sslclients"
svc keep-client-installed
svc split include
default-group-policy policy_1
aaa authentication list sdm_vpn_xauth_ml_1
gateway gateway_1 domain sslvpn
So basically, I would like to hand out addresses from my 2001:xxx:xxx:1::1/64 pool (it is also a routable /48)
Any help appreciated.
nicblais1 Fri, 06/12/2009 - 15:22
Thank you for your reply, do you know if it will be supported in the near future?
