VPN urgent help
Jun 11th, 2009
guys we have a pc which up loads and downloads files to a remote server at the other site....both the sites are connected via FR link....customer doesnt want permanent VPN......now only one pc does the uploads and downloads.....there requirment is that ..they only want VPN from that pc to the remote site only when the pc is uploading or downloading files as soon as its done the VPN shd be disconnected.....guys can someone recommend any solution any VPN client or some other thing.......i cant get my head around it plz help...thanks in advance
The_guroo_2 Thu, 06/11/2009 - 23:12
Thanks for your help but can you plz explain the whol setup.....do i need any thing on the remote end router....plz explain a bit thanks in advance
