Deos Aironet 1300 can provide the repeater mode to PT-link TL-WA601G
Jun 11th, 2009
I have a problem with Aironet 1300 to provide the repeater mode to PT-link TL-WA601G for extending the signal.
I have two cisco aironet, i have configures as the bridge to link each other and WEP 128bit key.
Then i bought TL-WA601G for extending the signal to my room. However after i configure on TL-WA601G as the repeater mode and put WEP 128bit key, TL-WA601G cannot get sent and received packets from Aironet.
So what is the problem on this? How can i solve this issues?
Anonymous (not verified) Wed, 06/17/2009 - 13:49
Cisco Aironet products can establish 40-bit Wired Equivalent Privacy (WEP) connections with IEEE 802.11b-compliant non-Cisco products. If you want to create a 128-bit WEP link, Cisco products only interact with other Cisco products. If you are using a third-party device with a Cisco Aironet product, you must set both devices to use 40-bit WEP.
Trending Topics - Security & Network
