ASA 5520 IPSec Tunnel - Unable to remove PeerTblEntry
I'm trying to create a site-to-site tunnel
between an ASA 5520 and a Cisco 2800
I'm getting "Unable to remove PeerTblEntry"
Can anyone give me some insight on what
the problem might be. This is the ASA side.
There's 20 other tunnels running. I'll try and get the other side ASAP (a vendor)
name 5.5.5.5 Vendor
access-list VPN_TO_VENDOR extended permit ip 10.20.12.127 255.255.255.255 10.127.23.10 255.255.255.255
access-list nonat_inside extended permit ip 10.20.12.127 255.255.255.255 10.127.23.10 255.255.255.255
access-list OUTSIDE_ACCESS_IN extended permit 10.127.23.10 255.255.255.255 10.20.12.127 255.255.255.255
nat (inside) 0 access-list nonat_inside
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map vpn_map 25 match address VPN_TO_VENDOR
crypto map vpn_map 25 set peer Vendor
crypto map vpn_map 25 set transform-set 3DES-SHA
crypto map vpn_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 28800
tunnel-group 5.5.5.5 type ipsec-l2l
tunnel-group 5.5.5.5 ipsec-attributes
pre-shared-key *
Farrukh Haroon Sat, 06/13/2009 - 05:41
  • Red, 2250 points or more
You should ignore that message I guess and look for more obvious error messages to get the tunnel up and running. What is exactly wrong with the tunnel?
Farrukh
