PEAP authentication on 877W
Jun 12th, 2009
I am setting up a 877w for home users. Essentially I have 2 Bridge groups, 2 Vlans and 2Wlans. All is working fine until I start on the PEAP configuration. On the switch port if I plug in my laptop it is properly authenicated against on our ISA/Radius. However, the wireless over and over doesn't even talk to the Radius. Can someone point me to a configuration that can help me see my error? I've added my configuration attempt if this helps.
Thank you.
dancampb Fri, 06/12/2009 - 08:47
I assume you are trying to use the SECURED SSID. If so you need to add the command "authentication open eap eap_methods" under it. Authentication network-eap is used for LEAP and EAP-FAST only.
Trending Topics - Security & Network
