BGP - Idle (PfxCt) now stuck in Active state
Jun 12th, 2009
I have a direct peer which has the following state:Idle (PfxCt).
To clear this, I did: clear ip bgp neigh
The thing is, it went to Idle and is now stuck in Active. I even increased the max-prefixes but it is still Active.
I can ping the neighbor.
Anyone else experienced this? How can I get this EBGP peer to Established state?
Harold Ritter Fri, 06/12/2009 - 03:56
It can be due to many different things. Can you post the ouput for the "show ip bgp nei " and the sanatized bgp configuration.
Giuseppe Larosa Sat, 06/13/2009 - 06:08
Hello Walter,
the state state:Idle (PfxCt) means the max-prefixes threshold has been passed.
try without a max-prefixes command or with an high max-prefixes they may be sending out a full table by error.
I see that now it is stucked in active.
You can wait some time, use neigh xx shutdown, no neigh xx shut.
You could use also some debug commands to see if you get any answer from the neighbor.
Hope to help
