Test VWIC-2T Card
Jun 12th, 2009
i am facing a problem with the VWIC-2T card.
i am having 2 links connected to the 2 interaces controller 0 & controller 1,
while pinging i am getting drops.
but when i swap the cables on the same interfaces i am able to ping.
i am suspecting a problem with the VWIC card, can any one help me in diagonising it.
slmansfield Fri, 06/12/2009 - 06:06
Can you post your configuration of the T1's? I'm wondering whether you are using PPP encapsulation. Are the T1's going to two different carriers?
When you say you swapped the cables, did you swap the cable going to the first T1 with the cable going to the second T1 so that the configuration for the first T1 is using the physical connection to the second T1, and vice versa?
