vpn client does not ping to internal network
Jun 12th, 2009
i have configured pix 515e for vpn client. i then installed cisco vpn client in my pc. now if i connect my pc to pix using the cisco vpn client ,i get connected and pc is assisgned a ip address from the pool i have configured in pix.my issue is : when i ping from pix to the pc it pings fine,but from the pc it does not ping to pix inside interface or pix inside network.
Please help
Overall Rating: 4 (1 ratings)
m.naresh@chennai Mon, 06/15/2009 - 01:55
the link you provided was very useful.
But still i am not able to connect.
In the vpnclient log i see the following message:
AddRoute failed to add a route: code 87
Your help will be appreciated.
Arul
mvsheik123 Mon, 06/15/2009 - 06:14
This error looks like more from your client end. Try to 'google' for solution. I would also try from PC connected directly to internet or wired connection (if your testing PC using wireless). Post the PIX head end configs here, Gurus may be able to help (if there is any head end config issues).
hth
MS
** Rate the useful posts**
m.naresh@chennai Wed, 06/17/2009 - 10:00
You are correct.
After installing the vpn client from 4.x to 5.x and after making few changes in pix config the issue was resolved.
Thanks for your help
