IOS upgradation on 6513 switch
Jun 12th, 2009
hi everyone! plz help me to upgrade the IOS of 6513 swich. Recent IOS version is 12.2(18)SXF7. I have two sup engines 720 series.
tarnhundal Fri, 06/12/2009 - 20:45
i have seen this document , actually i have to implement it on my core switch so plz tell me did u try this ? will this work fine ? there is one step in that delete the current file . after that will this work or not ?
tarnhundal Fri, 06/12/2009 - 20:35
actually not much sure . my requirement is that i have to implement some services like SLA which are not running on this IOS. I have to upgrade it on both 6513 and 7613. some times i m thinking abt SR but not sure . what u say abt it ?
Leo Laohoo Fri, 06/12/2009 - 23:45
I am sure no one here will recommend that you upgrade to a specific IOS unless you really need to. Even more, no one will also recommend an upgrade without testing the firmware in a test environment.
I will not be able to answer your question but I will urge you to take it upon yourself to test the firmware and/or read the release notes for any potential pitfalls you might encounter.
You can also do some research through Cisco's Software Advisory and Bug Traq.
tarnhundal Sat, 06/13/2009 - 00:10
thanx dear. this is main concern thats by i m not upgarding my IOS. so i m bit afraid that while upgrading there may b some problems. i m afraid of downtime .
tarnhundal Sat, 06/13/2009 - 22:24
yes . we have two sup engines . i have done redundancy between them
Leo Laohoo Sun, 06/14/2009 - 02:19
Copy the IOS to the master and secondary blade. Reboot the redundant blade and then reboot the primary blade.
tarnhundal Sun, 06/14/2009 - 02:25
i got it . means u r saying that i have to simply copy from tftp to file as we do with other devices . shud i need any other commands.
tarnhundal Sun, 06/14/2009 - 02:38
tarnhundal Sun, 06/14/2009 - 20:52
i m unable to access this page.can u plz send me this page after downloading it .
thanx,
tarn
