Collin Clark Fri, 06/12/2009 - 06:13
  • Purple, 4500 points or more
A syslog entry is generated by the device as a notification of something happening on the system. An example is that a NAT translation was created.
An SNMP trap is a log entry that is generated by the system that maps from a MIB. An example is a BGP session went down (which may or may not also be a syslog entry). Typically you use traps if you need something specific to be logged.
The logging host can used for both.
Hope that helps.
tech_trac Fri, 06/12/2009 - 07:36
How can I distinguish a syslog from an snmp trap on the logger where both the information is stored.
Thanks.
