ASA 5510 QoS configuration
Jun 12th, 2009
Hi forum,
We have some users who use citrix outside corporate network through citrix web interface.
These users are high priority users and we want to prioritize the citrix traffic.
I want to make sure that my configuration will fullfill our requirements. Below is the configuration i was thinking to implement.:
ASA(config)# priority-queue outside
ASA(config-priority-queue)# exit
ASA(config)#access-list CTX-QoS extended permit tcp any eq https
ASA(config)# class-map CTX-QoS-CMAP
ASA(config-cmap)# match dscp ef
ASA(config-cmap)# match access-list CTX-QoS
ASA(config-cmap)# exit
ASA(config)# policy-map CTX-QoS-PolicyMap
ASA(config-pmap)# class CTX-QoS-CMAP
ASA(config-pmap-c)# priority
ASA(config-pmap-c)# exit
ASA(config)# service-policy CTX-QoS-PolicyMap interface outside
Will this do the job?
Thanks in advance.
Ibrar Mohammad
BrinksArgentina Fri, 06/12/2009 - 10:00
You must enable priority queues on the physical interface. (VLANs do not suport priority queuing)
</p><p>priority-queue outside</p><p>
And it's recomended that you limit the "not so important" traffic, please refer to my post:
Please rate all the helpful comments.
ibrarmohammad Sun, 06/14/2009 - 23:21
thanks for your reply.
I believe that on Cisco ASA you enable it on the VLAN interface.
Otherwise - will the exampled configuration fullfill our needs regarding prioritizing the citrix traffic?
Thansk in advance.
Ibrar Mohammad
santiago.jem Tue, 09/25/2012 - 20:14
Hi Mohammad,
Sorry for crashing into the thread. May I know how was your implementation with this?
Im actually planning to implement the same. Prioritize Citrix Traffic.
Hoping to hear from you soon.
