ASA5510 ASA5510-K8 LAN Failover
Jun 12th, 2009
Can these 2 models do LAN failover provided images and licensing are correct? The firewalls are identical except for the show version models, one is the "K8" variant, whatever that is.
Thanks!
mwheinz Fri, 06/12/2009 - 06:44
Thanks for your reply. The referenced doc really doesn't say if the asa5510 and the asa5510-k8 are interoperable as regards failover. Have you set this up using the models in question?
Thanks!
Collin Clark Fri, 06/12/2009 - 07:10
The ASA5510 and the ASA5510-K8 are the same hardware models. They both need to run the exact same OS for failover. Upgrade to 8.2(x) if possible.
<font size="2"></p><p>FIREWALL# sh ver</p><p></p><p>Cisco Adaptive Security Appliance Software Version 8.2(1) </p><p></p><p>Compiled on Tue 05-May-09 22:45 by builders</p><p>System image file is "disk0:/asa821-k8.bin"</p><p>Config file at boot was "startup-config"</p><p></p><p>FIREWALL up 26 days 4 hours</p><p>failover cluster up 1 year 21 days</p><p></p><p><b>Hardware:   ASA5510-K8</b>, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz</p><p>Internal ATA Compact Flash, 256MB</p><p>Slot 1: ATA Compact Flash, 64MB</p><p>BIOS Flash AT49LW080 @ 0xffe00000, 1024KB</p><p></p><p>Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)</p><p>                             Boot microcode   : CN1000-MC-BOOT-2.00 </p><p>                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03</p><p>                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04</p><p> 0: Ext: Ethernet0/0         : address is 0019.e8d9.46f2, irq 9</p><p> 1: Ext: Ethernet0/1         : address is 0019.e8d9.46f3, irq 9</p><p> 2: Ext: Ethernet0/2         : address is 0019.e8d9.46f4, irq 9</p><p> 3: Ext: Ethernet0/3         : address is 0019.e8d9.46f5, irq 9</p><p> 4: Ext: Management0/0       : address is 0019.e8d9.46f1, irq 11</p><p> 5: Int: Internal-Data0/0    : address is 0000.0001.0002, irq 11</p><p> 6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5</p><p></p><p>Licensed features for this platform:</p><p>Maximum Physical Interfaces  : Unlimited </p><p>Maximum VLANs                : 100       </p><p>Inside Hosts                 : Unlimited </p><p>Failover                     : Active/Active</p><p>VPN-DES                      : Enabled   </p><p>VPN-3DES-AES                 : Enabled   </p><p>Security Contexts            : 2         </p><p>GTP/GPRS                     : Disabled  </p><p>SSL VPN Peers                : 2         </p><p>Total VPN Peers              : 250       </p><p>Shared License               : Disabled</p><p>AnyConnect for Mobile        : Disabled  </p><p>AnyConnect for Linksys phone : Disabled  </p><p>AnyConnect Essentials        : Disabled  </p><p>Advanced Endpoint Assessment : Disabled  </p><p>UC Phone Proxy Sessions      : 2         </p><p>Total UC Proxy Sessions      : 2         </p><p>Botnet Traffic Filter        : Disabled  </p><p></p><p>This platform has an ASA 5510 Security Plus license.</p><p></p><p>Serial Number: 99999999</p><p>Running Activation Key: XXXX XXXX XXXX XXXX XXXX </p><p>FW# sh fail state </p><p></p><p>               State          Last Failure Reason      Date/Time</p><p>This host  -   Primary</p><p>               Active         None</p><p>Other host -   Secondary</p><p>               Standby Ready  Comm Failure             06:10:17 CST May 17 2009</p><p></p><p>====Configuration State===</p><p>        Sync Done</p><p>        Sync Done - STANDBY</p><p>====Communication State===</p><p>        Mac set</p><p></p><p></font>
