obtaining call records from CDR
Jun 12th, 2009
I am running CCM 6.1
We need to pull our call records for a certain ext. THe problem i am having is in CDR is I go to CDR/search/User extensions and search.
It will only show 100 records and trunkcate the other. Now I need to pull 3 months worth and it would be to time consuming to do each day and copy it to a report.
I also attempted to goto device reports/gateway/detail and will puill ever 3 days the entire logs. This will put it in the PDF and allow me to search for that ext but its will not copy out of the PDF properly and I need to only show the ext I want.
Does anyone know a way I can get a detailed call report for only 1 ext that will not truncate the results? or another way I can access this.
In our older version of call manager (4.1) i was able to load sql and do a search on the DB and just copy the results out.
Overall Rating: 5 (2 ratings)
Jaime Valencia Fri, 06/12/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    2011
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
java
if this helps, please rate
Jaime Valencia Fri, 06/12/2009 - 12:30
  • Cisco Employee,
  • Hall of Fame,
    2011
Works in any CUCM version
java
Jaime Valencia Fri, 06/12/2009 - 12:56
  • Cisco Employee,
  • Hall of Fame,
    2011
No, thru CUCM CLI.
Directly on server console or SSH into server. Considering you might want to save the output, SSH into the server.
java
techie2008_2 Mon, 04/15/2013 - 09:44
The script worked like a charm in Putty!!  The out put came out garbled, but I copied it to the clipbaord and put it on Notepad and it was great!  Thanks so much!!
Anthony Holloway Mon, 04/15/2013 - 11:42
  • Purple, 4500 points or more
Since this old post is being revived, I should mention that in recent versions (too lazy to research exact) of CUCM, the syntax has changed slighty, and the above given command no longer works.
The new syntax is:
run sql car select * from tbl_billing_data where originalcalledpartynumber='911'
EDIT: In our very own forum member Will's blog, he states it was a change from 7x to 8x:
http://www.ucguerrilla.com/2012/03/cucm-sql-queries-installment-5.html
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
techie2008_2 Wed, 04/17/2013 - 07:30
I used with CUCM version 7.1.  So I'm not sur where the stop and start point is.  Anyway, thanks again!
