Flash Light on LightWeight AP?
Answered Question
Jun 12th, 2009
Hello
Is there a way through the wireless contorller(5.2.178.0) to flash the light on a 1250 series lightweight AP that is managed by that controller?
I have about 8 - 9 1250's that got deployed on a 30 foot high ceiling and didnt get their MACs documented or any identification put on them before they were installed. Id like to be able to identify each one without having to take them down(they are in use) or dig up a 30 foot ladder.
thanks
e-
Correct Answer by Rob Huffman about 8 years 2 weeks ago
Hi Eric,
Would turning the LED off one by one work?
I'm not sure if this works for the 1250, but maybe you could give it a try;
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco 1000 Series lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 06/12/2009 - 08:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Eric,
config ap led-state
Syntax Description
config
ap
led-state
{enable | disable}
{Cisco_AP | all}
Hope this helps!
Rob
Rob Huffman Fri, 06/12/2009 - 12:12
  • Hall of Fame,
    Founding Member
Hi Eric,
Great stuff! Thanks for letting us know this still works with the 1250 series.
Cheers!
Rob
Old thread but for people who want to do it through the GUI
Step 1  Choose Wireless > Access Points > All APs and then the name of the desired access point.
Step 2  Choose the Advanced tab to open the All APs > Details for (Advanced) page.
Step 3  Select the LED state check box.
Step 4  Choose Enable from the drop-down list adjacent to this text box.
Step 5  Click Apply.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
