How to enable CFwdAll on second line
A group of users that shared a line would like to forward all to voicemail before they leave for the day. The shared line is a secondary line in all phones, when I active the second line and press the softkey “CFwdAll” I get the message “The key is not active here” . Where can I active that key if the feature is available for second lines on a IP Phone?
Any feedback will be appreciated.
Iliana Dorsey
Jaime Valencia Fri, 06/12/2009 - 10:49
That's WAD
Use CCMUser or CCMadmin, you may also google:
IPPhone callForwarder
PLEASE, search previous posts, there are many, many, many posts on this same topic.
Try the Search NetPro at the right side to search for answers.
java
if this helps, please rate
Paolo Bevilacqua Fri, 06/12/2009 - 12:34
Java,
There's no point in asking people to search before posting.
The human nature prevents "them" to do so.
The only remedy would be an automated system that automatically answer certain questions, but that won't happen neither.
Thank you for your continued help!
