Parse data with UCCX 7
Jun 12th, 2009
I am opening this to the forum, as I am stuck. I get a value from the database, a 9 digit number, "033355555" and plug it into a string variable. It is a 9 digit number when I get it. I need to be able to strip the leading zero, put the next 3 numbers in variable and the remaining 5 in another to read them back to a caller. Any thoughts on this would be great!
Bill
Overall Rating: 5 (1 ratings)
molivere17982 Fri, 06/12/2009 - 18:13
Bill,
You need to use substring.
Look at my example below, it cuts out the first digit and the last 5 putting "333" in the variable firstThree and the second Set command chops off the first four digits and puts them in the variable otherFive.
Start
Set firstThree = db_string.substring(1, 4)
Set otherFive = db_string.substring(4)
End
Name Type Value Attributes
db_string String "033355555"
firstThree String ""
otherFive String ""
