Allow 3389, http, https
Jun 12th, 2009
Hi!
I have a 24 Ports Cisco 3750 Switch. Is it possible to configure any of its port to allow only 3389, http and https requests coming from the IP Range 192.168.10.71, 192.168.10.100 Mask: 255.255.255.0 and block all others ports and IP Ranges?
Thanks!
Laurent Aubert Fri, 06/12/2009 - 12:23
When you translate 71 and 100 into binary, it looks like:
71: 0100 0111
100: 0110 0100
Only the two first bits never change so the closest range to 71-100 is 64-127. So it doesn't worth it playing with the wildcard mask.
The ACL with the minimum number of lines will be the one with one line per IP address of the range 71-100 and per TCP port (29x3=87 lines):
access-list 100 permit tcp host 192.168.10.x any eq 3389
access-list 100 permit tcp host 192.168.10.x any eq 80
access-list 100 permit tcp host 192.168.10.x any eq 443
with 71<=x<=100
You can then apply this ACL in input on the port of the switch:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swacl.html#wp1667255
Laurent.
