load balancing and automatic failover between two isp on Cisco 1841
Jun 12th, 2009
hi all,
I have 2 Internet links (T1 and DHCP cable modem) need sample config to
load balancing and automatic failover between the two isp on Cisco 1841
afernandez0226 Fri, 06/12/2009 - 16:31
Thanks for the quick reply. I was looking at this article but am confuse on this line that only show route over just 1 ISP; so why there is not a route for the 2nd ISP
ip route 0.0.0.0 0.0.0.0 dialer 0 track 123
paolo bevilacqua Fri, 06/12/2009 - 21:45
  • Hall of Fame,
    Founding Member
Sometime the example configurations are not 100% correct. You can use the feedback form on the side to tell cisco about the mistakes.
