Firewall Configuration Issue
Jun 12th, 2009
i am having some issue while configuring PIX firewall in my network.
Please find the network digram for your refernce abt the setup.
As per diagram i am able to reach the firewall using inside interface ip address from remote end Lan.
but there is no traffic passing between outside to inside even if i kept permit ip any any ACL rule.
Can some one send me the basic configuration as per the network diagram.
It will be great help for me.
chaitu.kranthi Sat, 06/13/2009 - 01:11
Thanks for your quick reply,
apology for missing the configuration.
Please find the config & network diagram as attachment.
correct me if i am wrong at any where.
My requirement is outside lan has to access remote server through inside interface with out any nat.
Farrukh Haroon Sat, 06/13/2009 - 04:58
Can you mention any SPECIFIC flow you are trying to test?
e.g. telnet x.x.x.x port
Also your default route statement seems to be wrong:
route inside 1
The interface you mention is 'inside' but the next-hop is actually the FW's outside interface IP??
It should be the following I guess:
route inside 10.62.248.XX
Also is your inside interface mask correct? Is it supposed to be /27?
hussain.ratlami Mon, 06/15/2009 - 05:02
check your route command, it should be
route inside
also if you have done any Natting, you have to create a NAT exempt rule for the network range you dont want to b Natted.
Let me know for any help you require
