How to calculate BE value in QOS
Jun 12th, 2009
Hi, I want to implement QOS on Router R2 which has T1 line. R2 should attemp to average on output rate of 64Kbs on the circuit.
In case, R3 has accumulated Credit, it should allowed to send a Maximum of 12Kbs of data is a single interval. You can use 125ms default as Tc. I know 8000 will bc, What would Be ?? Please help
Giuseppe Larosa Sat, 06/13/2009 - 06:59
  • Hall of Fame,
    Founding Member
Hello Rupesh,
you didn't write what kind of action you are doing I guess you are shaping.
you need to be able to send 12000 bits in a Tc if credit has been accumulated.
Each Tc you get 8000 bits that can be held in two buffers Bc and Be.
if Bc is 8000 to be able to handle 12000 bits in a single time interval the second buffer size has to be:
Be = 12000 - Bc = 4000
Hope to help
Giuseppe
