PBR
Jun 13th, 2009
When configuring class-map/policy-map... where will the application command "service-policy in/out XXXX " be applied?
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Sat, 06/13/2009 - 07:45
Under interface, subinterface, VC, VC-class and the like.
Note that is called MQC and not PBR.
thotsaphon Sat, 06/13/2009 - 12:21
Kennie,
It depends, You cannot apply some MQC in the inbound direction(Let's say CBWFQ). You cannot apply MQC directly under the frame-relay sub-interface.
QOS,let's start from here : http://supportwiki.cisco.com/ViewWiki/index.php/Category:Quality_of_Service_(QoS)
In case you are interested in PBR. Here you go : http://supportwiki.cisco.com/ViewWiki/index.php/Category:Policy_Based_Routing_(PBR)
HTH,
Toshi
