Send call to next Skillgroup if the call is not answered
Jun 13th, 2009
In uccx 7, if the call is not answered on the agent ip phone after ringing for sometime, can the call be sent to the next skill group / next node on the script. Also note that after the ring-on-no-answer, the agent state has been configured to be Ready.
I tried putting the Goto LABEL on the failed node of the select resource, however call does not go to the LABEL in the script.
Thanks.
david.macias Sun, 06/14/2009 - 19:30
  • Blue, 1500 points or more
Make sure you double click on the skill group node and enable requery, then you will be able to re-route the call on RONA. Check the SRND or the scripting guide on details on how to do this.
david
csshenoy80 Mon, 06/15/2009 - 03:40
hi david,
we have uccx-express, the step you suggested is for ucce-enterprise.
Thanks.
