Route calls on Router based on Calling Number?
Jun 13th, 2009
Hi Gurus,
Is there any method yet to route outgoing calls based on calling number on a gateway apart from blocking incoming calls based on the calling number?
Overall Rating: 5 (2 ratings)
Marwan ALshawi Tue, 06/16/2009 - 03:10
you could also use answer address on your inbound voip dial-peer and translate the matched number to whatever you want then the translated numr will match a pots dial-peer
ShailendraK Thu, 06/18/2009 - 02:55
Hi guys,
Thanks for replying. It worked for me.
Paolo, I am still not able to get over the incredible feeling of the new friend pri-group. So I will not answer that question yet. Maybe later sometime. Let me enjoy the moment. ;)
