French BRI Configuration
Jun 13th, 2009
HI all,
What's the french configuration for BRI?
-          Basic 5ESS
-          Basic DMS100
-          Basic NI
-          NTT
-          Basic NET3
-          Basic 1TR6
-          VN3
-          Basic QSIG
and
Bearer capability : speech or 3100 HZ or none
and
ISDN Static TEI : none,0,1,2,3,4,5,6,7,8,9
Marcos Hernandez Sun, 06/14/2009 - 06:36
This is a sample CLI configuration for a BRI connection in France:
isdn switch-type basic-net3
interface BRI0/1/0
no ip address
no logging event link-status
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
Bearer CAp. should be "Speech".
Some configurations require a static TEI, typically "0". Finally, sometimes inbound calls fail due to the fact that IOS disables the dial-peers when the Layer 1 goes down. To avoid this, you will need to enter this global command: "no dial-peer outbound status-check pots".
Marcos
final-reseaux Sun, 06/14/2009 - 08:04
Where i paste this line:  "no dial-peer outbound status-check pots".
final-reseaux Sun, 06/14/2009 - 09:54
this is BRI Port conf with CCA 2.0, is it true or not
interface BRI0/1/0
no ip address
isdn sending-complete
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
