Jun 13th, 2009
I have an NMS that I use to poll my devices with SNMP. I want the device to send log to the syslog server when ever it is polled.
cisco_lad2004 Sun, 06/14/2009 - 01:29
What are you trying to achieve here ?
If NMS is configured correctly, it would poll quiet regularly and in this case do you wnat to overwhelm both your network and your syslog server with unnecessary entries and traffic ?
If you simply want to validate that NMS is polling every 5min, you could use a sniffer so you can see both poll and reply...after that the system should take care of itself leaving syslog to take care of more serious issues.
Marvin Rhoads Wed, 06/17/2009 - 07:29
I concur with the original response, but if you really want to do this...
For CatOs:
set logging level snmp informational
For IOS:
logging buffered informational
This is likely to fill up your log and produce a lot of noise in which you may be hard pressed to distinguish the signal you are trying to see.
should do it.
