HSRP: Track
colmgrier
Will this work for two core switches running HSRP. Basically I want HSRP running between the switches and also to track interface gig1/1 on the coreA switch.
!- CoreA
interface Vlan2
ip address 2.0.0.2 255.255.255.0
ip helper-address 2.153.20.25
no ip redirects
no ip proxy-arp
standby 2 ip 2.0.0.1
standby 2 priority 105
standby 2 preempt
standby 2 authentication C1sc0
standby 2 track gig1/1
inter gig1/1
switchport
switchport access vlan 2
swithport mode access
!- Core B
interface Vlan2
ip address 2.0.0.3 255.255.255.0
no ip redirects
no ip proxy-arp
standby 2 priority
standby 2 preempt
!- Router 1 att to Core A (gig0/1)
int g0/1
ip address 2.0.0.100 255.255.255.0
6 Replies 6
Edison Ortiz
I see nothing wrong with the config, it should work as intended.
__
Edison.
cisco_lad2004
Level 5
Level 5
a very small detail, u need to set priority on core B if u intend to use a different value from default...I am sure its a copy and paste typo.
Sam
Sam,
The default decrement is 10 and the primary has priority 105, thus the configuration looks fine.
In case of failure, the primary will have priority 95 and the standby will have priority 100 (default).
Edison,
I know :-)
But the fact that second device has "standby 2 priority " suggests that there is an intended value planned for priority.
IMHO, we cannot tell if the config is fine until we see what value has been planned for second device.
However,if the config is pasted as is, this particular line would be rejected since "standby 2 priority" with no value is not valid syntax and second device would then use 100 default.
Sam
mahmoodmkl
Level 7
Level 7
Just to add to the above posts isee that u havent specified the vlaue of the priority to be decremsted in case of the gig1/1 goes down.
Mahmood
Mahmood, good point !
Default tracking penalty is 10..so all depends on how much will be assigned to standby.
Sam
