MPLS, what device should I use?
Jun 13th, 2009
I am practicing CCIE lab and the new lab requires implementing MPLS VPN. However seems my 2610XM router doesn't support it!! I have tried all the possible IOS (Advanced IP/Enterprice and even SP) and none of them supports the MPLS configuration... It's really disappointed as I just bought five 2610XM routers... So does anybody know if there is an image for 2610xm which supports MPLS? If I need to buy new device, what model should I choose? How many do I need? I mean CCIE lab suggests 3825 but I really can't afford it... Any cheaper replacement for it??
Thank you in advance!
Difan
leekleybm Sun, 06/14/2009 - 16:56
You can use dynamips, and not have to purchase anything extra. Use the 7200VXR and 3640 images, and you should be set.
