cisco Device Inventory, need help
Jun 13th, 2009
My data center, HO and Branch office use a lot of Router and Switch. somes device are add my network and some are gone for meintenence . so its a big trouble to manual handle the device . My concern is to deliver the status of devices position at a glance.
so any one suggation which software can help the the task easily done.
redrobish Sun, 06/14/2009 - 16:58
Hi biplobhan,
In my network, i used the free "Switchmap" from sourceforge. it's swtich mapper. There's a search function there to help you search & list the model of the router/switch/phone you have. it is based on the arp so basically it works on Cisco devices (not sure on other brands)
check this out:
Also there's the solarwind's "lan surveyor" which have the ability as the Switchmap but it's not free.
Just a suggestion...
hope this helps
biplobkhan Sun, 06/14/2009 - 20:24
Thanks your replay its helpfull.
actually i need the entry of inventry when the device send to sites. that time i need entry the software and find out any time the status of devices. if you any software like that please inform.
