VSS-Configure SVI interface
Jun 13th, 2009
Configured VSS successfully on 10 GE port, after that trying to configure SVI vlan interface but interface state in down .
1. configure vlan 30 in vlan database
2. configre interface vlan 30
ip add x.x.x.x x.x.x.x
anything else i am missing . please advise.
Thanks and Regards,
Milind Tare
iyde Sun, 06/14/2009 - 00:06
conf t
vlan 30
name Management (or whatever name you want it to have)
int vlan 30
ip address x.x.x.x x.x.x.x
Then the VLAN has to be active on a port or a trunk. With that you should be fine.
milind.tare Wed, 06/17/2009 - 07:23
One more problem i am facing , trying to connect 4506-e switches to VSS but not able to configure etherchannel bundel. in fact interfaces are in Down and Down state.
please advise.
Thanks and Regards,
iyde Sun, 06/21/2009 - 12:14
Hi Milind.
Could you post the config from the VSS as well as the 4506-E in order to show what you've tried?
Rgds, Ingolf
