WAE inline or WCCP on data center
Answered Question
Jun 13th, 2009
  • Bronze, 100 points or more
Hi all,
Is WAE(674)inline mode fine for data center or should I go for WCCP?
Any idea about throuput of inline adaptor?
Correct Answer by dstolt about 7 years 11 months ago
Hi Nomair,
I usually start with WCCP in the DC due to the fact that you are limited to intercepting on 2 links with the inline card currently and most DC scenarios have requirements of using more then 2 links (or routers).
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Tue, 06/16/2009 - 05:22
  • Cisco Employee,
Hi Nomair,
Dan
nomair_83 Wed, 06/17/2009 - 07:28
Ok thanks I will use wccp.
One more thing, can I use 674 as WAE appliance and 512 as CM who will manage 674 appliance or I have to use same appliance for CM as well?
dstolt Thu, 06/18/2009 - 17:36
  • Cisco Employee,
CM size is based on how many WAEs it will be managing. A 512-2 GB WAE can manage around 1000 WAEs, a 1 GB 512 roughly half as much.
Good luck!
Dan
nomair_83 Sat, 06/20/2009 - 22:27
Thanks dear,
I already have ordered additional 1GB memory.
thanks for your feedback.
