3560 using extended ACLs not marking all Voice traffic.
Customer is using OCS for Voice and Video conferencing and is pre-marking packets and we are using extended acls to mark traffic and mls qos trust dscp on user ports to trust dscp values. See config below. (The 3560 isn't capable of displaying stats for show policy map int <fax/xx> and there are no hits on the access-lists.) Show mls qos int <fax/xx> stats do show dscp markings and DSCP value 34 incrementing during Video conference sessions. DSCP values 40-47 are mapped to queue 1 so Video would go in queue 4 which it services in a weighted round robin manner with other traffic. We are using Wireshark packet captures which reveal that only about 15 - 30% of packets remain marked after going through our access switch.
(Switch is running the following image - c3560-ipbase-mz.122-50.SE1.bin)
mls qos
class-map match-any citrix
match access-group 103
class-map match-any video-and-sip
match access-group 102
class-map match-any voice
match access-group 101
policy-map mark
class voice
set dscp ef
class video-and-sip
set dscp af41
class citrix
set dscp af31
class class-default
set dscp af11
interface FastEthernet0/1
description *** User ***
switchport mode access
priority-queue out
mls qos trust dscp
no snmp trap link-status
no cdp enable
spanning-tree portfast
service-policy input mark
access-list 101 permit ip any any dscp eq ef
access-list 101 permit udp any any range 16400 16499
access-list 101 permit udp any any eq 5004
access-list 102 permit ip any any dscp eq af41
access-list 102 permit tcp any any range 5060 5061
access-list 102 permit udp any any 5060
access-list 103 permit tcp any 10.224.252.128 0.0.0.128 eq 2598
access-list 103 permit tcp any 10.224.253.0 0.0.0.128 eq 2598
access-list 103 permit tcp any 10.196.144.0 0.0.0.128 eq 2598
access-list 103 permit tcp any 10.196.147.0 0.0.0.128 eq 2598
Why isn't the switch trusting the dscp values?
Overall Rating: 2 (1 ratings)
parshah Mon, 06/15/2009 - 12:50
  • Cisco Employee,
I see that your access-list 101 is set for range 16400 - 16499.
Per RFC, RTP uses even ports between rage 16384-32767. Now, MS might have a different range but to verify can you change the access-list 101 to the range per RFC and see if it helps.
Also, which packets are not being marked? voice, voice, signalling?
Florin Barhala Thu, 06/25/2009 - 06:16
  • Bronze, 100 points or more
Hy,
I don't get it. With class-map Voice you're catching all the traffic with DSCP value set to EF. (ACL 101).
Then why you set AGAIN this traffic with DSCP value EF, in your policy-map?
parshah Thu, 06/25/2009 - 09:08
  • Cisco Employee,
Can you tweak you ACL and class-map as such
mls qos
class-map match-any signalling
match access-group 104
policy-map mark
class voice
set dscp ef
class video
set dscp af41
class citrix
set dscp af31
class signalling
set dscp cs3
class class-default
set dscp af11
priority-queue out
mls qos trust dscp
no cdp enable
access-list 102 permit ip any any dscp eq af31
access-list 104 permit tcp any any range 5060 5061
access-list 104 permit udp any any 5060
parshah Thu, 06/25/2009 - 10:38
  • Cisco Employee,
What I am suggesting is to seperate video packets and signalling packets and have different dscp markings per the Cisco QoS recommendations.
Usually, video packets are AF31 or AF41, so that is what you should be looking at. I don't entirely agree with your config where you match the packet by DSCP marking and re-mark them. You are just adding additional overhead.
Ideally, if you want to re-mark the packets, you should be matching them by protocol and ports and not by dscp marking.
Anyway, the config I sent you, I just want you to try that and see if the switch is marking the video packets properly.
parshah Mon, 06/29/2009 - 08:56
  • Cisco Employee,
In your policy class, you are re-marking your traffic. So even though the ACL matches video packets that are AF41 and AF31, the policy map will re-mark it to AF41. So you should not have issues.
Anyway, the reason I am asking you to try this is to find out if there is a likelihood that there were some video packets that were AF31 and were not being marked properly.
Like I said before, the QoS config you have is not as recommended by QoD SRND and you might come across issue in future as your network grows.
