06-14-2009 01:18 AM - edited 03-06-2019 06:14 AM
I have been configuring ip dhcp snooping IPSG and DAI on a LAN infratsructure and am having an issue with IPSG. The user guide states that to use "ip device tracking" for static hosts you have to do the following:
Global:
ip device tracking
Interface:
ip device tracking maximum <n>
ip verify source tracking [port-security]
The IOS will not let me enter the command "ip device maximum" and therefore the function does not work. The IOS I am using is 12.2(44)SG.
Can anyone help ?
Solved! Go to Solution.
06-14-2009 07:09 AM
If you are using Sup6-E, that feature isn't supported. It's described in the documentation:
HTH,
__
Edison.
06-14-2009 07:09 AM
HTH,
__
Edison.
06-14-2009 10:24 AM
thanks I missed that
