EZVPN trouble on PIX/ASA
Jun 14th, 2009
Hello all!
I've been facing this problem when i try to work a remote-vpn lab on GNS .
It's a simple setup
INSIDE ROUTER : 2691-adventerprisek9_sna-mz.124-13b
PIX : v8.03
The cloud represents my PC as you all know.
I've set up everything to the best of my ability and according to cisco documentation, but everytime i try to do a ezvpn connection to the firewall from my PC, the VPN client doesnt connect to the PIX. I tried turning on the debug in the PIX and i saw the output ( Seen in the attached screenshot.jpg ).
Please let me know what the problem is?
The settings on the VPN-Client are
Group : VPN_GROUP
password : cisco
host : 10.1.1.12 ( PIX's outside interface ).
Anyhelp would be appreciated!
Cheers!
Tacack
ybtheneonet Sun, 06/14/2009 - 08:17
I added the default-group-policy VPN_GROUP under the general-attributes of the tunnel configuration, but still not working!
paul@lexnetinc.com Sun, 06/14/2009 - 09:57
Is that the group name that you specified in your client as "Group Authentication Name" well? Also, does the password on the client, match the pre-shared key set on the group? I really don't think it is getting to the point to match the key though. Also, you may want to do a "debug crypto isakmp 128" to get more information.
