ACE Leastconn question
Jun 14th, 2009
I had just moved one server farm from round-robin to leastconns with slowstart of 300 second and no new rservers had been added (or failed), they are all the same as before the change.
What I see is that one rserver gets much more hits than other and one of them is practically idle. I know that CSCso93479 states that current connections count in "show serverfarm" is inaccurate, but I cannot understand such a difference....
Is total connections counter bugged as well?
real weight state current total failures
rserver: prmesapp11 8 OPERATIONAL 23 6 0
rserver: prmesapp12 8 OPERATIONAL 44 187 0
rserver: prmesapp13 8 OPERATIONAL 31 43 0
rserver: prmesapp14 8 OPERATIONAL 27 62 0
Or am i missing something about leastconns predictor?
Thanks a lot!
Overall Rating: 4 (1 ratings)
dknov Mon, 06/15/2009 - 10:28
Nope. I was trying to see what I can do about this, so I removed the leastconn (reverting back to round-robin) then configured leastconn back, but without slow-start parameter. What I immediately noticed is that servers started to be hit in a more equal manner, which is what I expected. I then reapplied the leastconn command, but with slow-start parameter and it would seem that session distribution was as expected. I assume that maybe removing and reapplying leastconn command did the trick, or maybe slow-start parameter was somehow misbehaving when I first applied it....
Now what I noticed is there are some sessions under failure column of "show serverfarm" output and I don't believe I had those before I switched to leastconn. The number is very low, like 5 failed versus 30,000 total, but still I was wondering if there is anything different with leastconn from round-robin that would cause some of the sessions to fail ?
Gilles Dufour Tue, 06/16/2009 - 06:16
we have a few slowstart issue where the internal data structure could get corrupted preventing some servers to receive traffic.
You may have hit such a problem.
CSCsx80991: ACE: Leastcon negative weight after adding new rservers
Usually, removing/adding the predictor does fix the problem.
Next time you see the issue, you should open a service request to receive guidance on what information to collect.
The procedure is not as easy as show ....
Regarding the failure, it is independent of the predictor.
We count a failure when the connection can't be established.
Reset from server or no response.
