accessing system via ipsec vpn
Jun 14th, 2009
In the scenario,main office is connected to the branch office via ipsec vpn.We want to access two systems in our main office from brance office.But can access only one of the two at a time when connection established.can any one tell what is the issue.
Thanks in advance.
auraza Mon, 06/15/2009 - 12:40
  • Cisco Employee,
Please can you paste the configuration, and the IP's you are trying to access.
Also, when you say that you are only able to access one at a time, are you saying that you can only get to one, and not the other at all, or that both are reachable as long as they are not accessed simultaneously?
seekhpar121 Wed, 06/17/2009 - 22:49
Thanks for reply.
detail is that,
Site A is using strong swan for Ipsec vpn tunnel to site B having PIX
for VPN tunnel.
There are two servers on two different subnets at siteB.
Want to access both systems from siteA via ipsec tunnel.
But can access only one system means,we can ping system 1 at B and can't ping sytem B.
when we reconnect,then we can ping system2 but cannot ping system 1.
We want to access both systems simultaneously.
Waiting for response.
auraza Thu, 06/18/2009 - 05:08
  • Cisco Employee,
If you can post the configuration of the PIX here, I can take a look.
