trevora Mon, 06/15/2009 - 02:32
There are 2 ways you can do this.
if you are using static nat then there are options that you add:
static (inside,outside) 1.1.1.1 2.2.2.2 70 50
= 70 Max connections and 50 embryonic
The more recent way is via policy:
class-map MYCLASS
match any
policy-map MYPOL
class MYCLASS
set connection {conn-max number | embryonic-conn-max number |
per-client-embryonic-max number | per-client-max number | random-sequence-number {enable |
disable}}
set connection timeout {tcp [reset]] [half-close ]
[embryonic ] [dcd [ [max-retries]]]}
service-policy MYPOL interface outside
abinjola Mon, 06/15/2009 - 03:39
  • Cisco Employee,
you mentioned about Pix, so make sure it runs 7.x as MPF is supported only 7.x onwards
jeansamarani Mon, 06/15/2009 - 04:33
but what's the difference between the max connection parameter and the embryonic value?
