Jun 14th, 2009
Can I use LDP FRR for acheving faster convergence in my MPLS backbone. Is it an IEEE standard mechanism for acheving faster convergence like MPLS_TE using RSVP.
drubiogr Mon, 06/15/2009 - 12:29
Thanks a lot for the link Anil,
Indeed, Cisco is not implementing LDP FRR and I did not hear any plans to support it in the near future, we went for the IPFRR option which by the way can also protect MPLS traffic.
Best regards,
anil12345 Tue, 06/16/2009 - 00:30
Hi Daniel,
can paste basic configuration for IP FRR. I am not able to access the Link sent by you earlier as it is giving restricted link.
Thanks & regards
drubiogr Tue, 06/16/2009 - 09:09
Hi Anil,
Here an example of IPFRR configuration. Note that you have to enable it on a per interface basis.
router isis 1
set-overload-bit on-startup 360
is-type level-2-only
net 47.0001.0004.0004.0004.00
nsf ietf
log adjacency changes
address-family ipv4 unicast
metric-style wide
interface Loopback0
interface GigabitEthernet0/7/1/0
circuit-type level-2-only
bfd minimum-interval 50
bfd multiplier 3
bfd fast-detect ipv4
ipfrr lfa level 2
anil12345 Tue, 06/16/2009 - 23:19
Some queries in regard to IP FRR.
a) Is IP FRR supported in IS-IS only;is it supported for OSPF.
b) Can I implement IP FRR in my MPLS backbone for fast convegence instead of MPLS TE.
And is the configuration that simple; only one command between neigboring routers.
ipfrr lfa level 2 + BFD commands
3) Which one is recommended IP FRR or MPLS -TE FRR for link failure/ Node failure protection & convergence times around 150ms as I am going to carry voice traffic across my MPLS Backbone.
drubiogr Wed, 06/17/2009 - 06:19
To answer your questions:
a) IPFRR is only supported today for ISIS, OSPF is in the roadmap but not available yet
b) Yes, you can implement IPFRR in the core instead of TE FRR to protect IP and MPLS traffic
c) The pro's of IPFRR are its simplicity, requires no interoperability, requires no signaling and no IGP extension. The con's, it does not offer 50msec reroute for all types of failures as TE FRR. Statistically speaking it can offer ~50msec for ~75% of the link failures
Sherif Atef Ahm... Sun, 09/29/2013 - 08:33
Hi Daniel/All
I have few questions please
1- If we used IPFRR to protect MPLS traffic, does this mean there would be a label assigned to backup paths ?
2- If yes then what the difference between this and LDP FRR as according to what I understand whole objective of LDP is to assign a label so if a label is assigned by IPFRR then technically they should be the same , correct ?
3- You mentioned "Statistically speaking it can offer ~50msec for ~75% of the link failures"
I believe this would be the case with pre-prefix protection (i.e. not per-link protection) .. Now the question is there a way to find out what are the prefixes that were not protected by IPFRR ?
Million thanks for your assistance
Sherif Ismail
