does 1801 support dsl2
Jun 15th, 2009
Hello
I am trying to get DSL2 working with an 1801. The circuit will not come up with the current code. I attach relevant show commands from the router.
Can a code upgrade resolve this or do I need new hardware?
Donagh.
paolo bevilacqua Mon, 06/15/2009 - 01:07
  • Hall of Fame,
    Founding Member
Circuit is up:
Modem Status: Showtime (DMTDSL_SHOWTIME)
so you have a different problem, try debug ppp neg or debug ppp auth.
donaghq_2 Mon, 06/15/2009 - 02:16
Hi thanks for your reply. I need to make myself more clear!
The circuit works at the moment with its current DSL settings. When the DSL gets upgraded to support higher bandwidth (DSL2) the circuit will not come up. Therefore the provider has to abandon the changes to keep the circuit working.
Donagh
donaghq_2 Mon, 06/15/2009 - 02:51
thank you. I will certainly give that a go. I will let you know how I get on will rate then.
