exterlan LED satus 1131AG - turn it off
Answered Question
Jun 15th, 2009
hi
this weeken i setup a wireless network in a large house and everything is working perfectly. the only complaint i received was that hte external led light is very bright when it gets dark (as it is located in one of the bedrooms this is a bit of an issue)
i found the following command
AP1(config)#led display ?
dim Turn LED display dim.
off Turn LED display off.
AP1(config)#led display off
i applied the above command but i have no way of veryfing (as i am not on site) if the external led has now turned off.
i could not find a command to show me the current led status (on/off/dim)
so 2 questions
1) will this command have turned off the external LED
2) how can you verify via the command line what the current status is
many thanks
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Rogier,
Yes, this command should have fully darkened the LED Display;
This example shows how to turn-off the 1130AG Status LED:
AP(config)# led display off
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/command/reference/cr43main_external_docbase_0900e4b180443057_4container_external_docbase_0900e4b180480623.html#wp3339779
This should be seen in a "show run" for the AP
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 06/15/2009 - 05:00
Hi Rogier,
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
