IPT signalling question
Jun 15th, 2009
I was hoping that you would be able to answer a question for me.
We have a Cisco 1750 voice gateway that is processing calls for our Call Manager that is connected to an O2 bearer using Q-Sig. O2 have just changed their backend and need to remove DPNSS and reconfigure to work with Q-Sig.
The question is whether the of signalling package we use would be Corenet NQ or Corenet N.
bobclose Fri, 06/19/2009 - 10:20
Hi Andy
Cisco's UC Interoperability lab has performed Integration testing with a Siemens Hicom 300 as well as a HiPath 4000 using the QSIG protocol. Details are presented in the form of an application note and can be found at: www.cisco.com/go/interoperability
If this does not address your question please re-post and include information as to the far-end that you are connecting to so that we may investigate further.
